Sodium filled exhaust valves? Are they standard fitment to S2's?
Ahh! Sorry! I forgot to say that on the 7A exhaust valve i cut...except the 027611D mark on top..(over the groove) is..under the groove..the following: T-T 33213 98.
Maybe this is helpful.Comment
Thanks so much for posting those photos. At least we know what once was.
The sodium-filled 027109611B exhaust valve = 3B, AAN, ABY and ADU sodium-filled exhaust valves
Note: When you do a cross check on 611B, it also shows up as the 1987 NM and 7A exhaust valves.
To confuse matters more, the non-sodium filled, 027109611D shows up as the NM and 7A exhaust valves also (
) as far back as 1987.
Maybe the 7As got the 611Bs at the same time that they got the bundle of snakes tubular header - that is until the bean-counters in accounting put a stop to over-building the 7A.
The 7A valve i cut was from an engine with the tubular exhaust manifold. I dont know what hapend in the past...but...iff you go to Audi now and order the 611B...you will receive the sodium filled valve.Comment
Is there a check to test if the valves are sodium filled from the outside (without cutting them)?
Also are there people running 7A valves on high HP applications?
I checked at a time the valves with a magnet and the 7A intake valves where strong magnetizing all the way and the exhaust valves not.Go Holset or Go RS4Comment
Sodium filled valves are not recomended if you have uprated valve springs and run high rpms.. they have a risk of splitting.Comment
7A motor
The 7A (and NM) had sodium filled in the beginning at least - see attached image taken from http://www.volkspage.net/technik/ssp/ssp/SSP_93.PDF
Nice collection BTW : http://www.volkspage.net/technik/ssp/index_eng.php/Attached FilesCheers, Torben
'94 B4 Avant S2Comment
1986 Audi 90q
724hk@2.2bar, 855nm@2,7bar, presisjon 5862 CEA Billet, 7a cams E85
Thanks to RFS Performance
2004 VW Touareg 3,2
2004 VW Multivan 174Hk Tdi Highline
sigpicComment
