DEKA vs EV14
  • Nik0las
    • 1345
    • Country: Bulgaria
    DEKA vs EV14
    What is the main difference?
    I can find Deka's 850cc on really good price should I skip and jum to ev14's??
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    Main advantage is the good efficiency of the EV14 on idle and low rpm, whereas the dekas on higher cc are not that good
    sent with Nokia 6210
    • Nik0las
      • 1345
      • Country: Bulgaria
      as far I know if you use stand alone ECU like LINK Vipec etc. you can ajust the timings... Personaly I have seen few cars with 875cc deka's + Link's and they had perfect Idle
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        Have you?
        I have always seen evo's highly tuned that run like s&*$&t on idle or they call idle 1300rpm!
        • Jelle..
          • Mar 2012
          • 52
          • Home: Netherlands
          Maybe an aggressive cam causes that.
          • A80Avant
            • Sep 2005
            • 10873
            • Country: Greece
            That too. But with large injectors rarely can you get an idle of low rpm and lamda 1. But yes aggressive came will do that too.
            • URquattroGus
              • Aug 2007
              • 547
              Watch out, the injector police will be along soon!
              Angus
              (1984 ur quattro)
              • Thuppu
                • 4115
                Isn't it well known, years ago, that Decas arn't the best choise for perfect idling and low emissions? Well, you can get perfect idling with quite big 1200cc EV14, even on the Motronic.
                • Nik0las
                  • 1345
                  • Country: Bulgaria
                  for 850cc EV14 - Do I need spacers and adapters? Or plug and play?
                  • Thuppu
                    • 4115
                    Yes, you need them both.
                    http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
                      It's to do with pulse width linearity ev14 are linear down to around 0.7ms iirc whereas dekas are only 1.5 so with large dekas where you need small pulse width you will get a ropey idle
