Help! fresh ideas needed...
  • 1781cc
    • Nov 2011
    • 1253
    hi peeps,
    Having an issue with the running of my car that I cant seen to solve and its really doing my head in... car seems to idle fine when starting up but as soon as its warm after a quick drive the idle moves between 700rpm and 1300rpm all by itself, at a continual, regular cycle.
    So, I thought it was my throttle body, I cleaned it and did a throttle adjustment using VCDS, made no difference, checked for air leaks, couldnt find any... checked for a boost leak, couldn't find any... disconnected the MAF, makes no difference to the idle.
    Needless to say when its running, its not making full power and feels sluggish.
    I replaced the throttle body, and the hose that runs from the top of the dump valve to the inlet as it was looking scruffy and there could have been a hole in it, no difference...
    I am guessing the hunting is down to an air leak, but I just can't find it!
    ORIGINAL ERRORS AND LOG BEFORE CHANGING THROTTLE BODY
    Saturday, 13 October 2012, 09:02:58:4907
    VCDS-Lite Version: Release 1.1
    Control Module Part Number: 8D0 907 557 T
    Component and/or Version: 1.8L R4/5VT MOTR HS D06
    Software Coding: 04001
    Work Shop Code: WSC 00000
    VCID: 41F5D52C5887
    4 Faults Found:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-00 - -
    01165 - Throttle Body Control Module (J338)
    17-10 - Control Difference - Intermittent
    00670 - Throttle Position Sensor (G127)
    06-10 - Signal too High - Intermittent
    17953 - Throttle Valve Controller: Malfunction
    P1545 - 35-10 - - - Intermittent
    ERRORS AND LOG AFTER CHANGING THROTTLE BODY
    Monday, 15 October 2012, 10:14:40:4907
    VCID: 41F5D52C5887
    2 Faults Found:
  • benntenn67
    • Jun 2009
    • 859
    An inlet manifold gasket leak or maybe the ISV ??
    Audi S2 Coupe 1995
    VW Passat GL5 (hatch) 1986
    VW Passat GL 1.8 (saloon) 1986
    Carrera Subway 8
    • 1781cc
      • Nov 2011
      • 1253
      hi mate,
      My car apparently doesnt have an ISV? I checked all the gaskets - looks fine to me... any other ideas? lol
      My car is a 1999 Passat 1.8T AEB automatic wagon, Mfr'd in Germany in 09/98. How can I tell if it has an idle stabilization valve (ISV) or not? Apparently this is pertinent info if attempting a throttle body alignment. Please let me know if you can help identify. TIA!
      • benntenn67
        • Jun 2009
        • 859
        Another thing to try is all the vacuum lines, esp the braided rubber type ones - these tend to fail at the ends ??
        Audi S2 Coupe 1995
        Carrera Subway 8
        • 1781cc
          • Nov 2011
          • 1253
          will try all those again - its really annoying, the braided one that runs from the dump valve has been done, it was a mess, but still got the problem, might try and replace all the vacum hoses throughout with silicon ones. I have a pile in the garage from my prelude days.
          bloody car!
          • chiefmechanic
            • Mar 2008
            • 198
            Kamei
            Hi lee, sent you a pm about the kamei rear spoiler. Brian
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              Check the voltage at the throttle motor....i think is the voltage problem...ignition switch or main fuse relay panel plugs...(poor connection somewhere)
              Hope this helps!
                Either a voltage issue or idle stabilser valve i reckon
                • 1781cc
                  • Nov 2011
                  • 1253
                  thanks for the voltage pointers guys - will look into that today!
                  • 1781cc
                    • Nov 2011
                    • 1253
                    working away at the moment so progress has stalled, but that said, I am having issues still with the idle and running of the car.
                    so far I have replaced:
                    - throttle body
                    - several air hoses
                    - lambda sensor
                    - coolant temperature sensor
                    - diverter valve
                    - replaced several breather system components
                    - throttle gasket
                    I still have the following errors on VCDS:
                    Voltage at the throttle body is apparently fine, and this AEB engine doesn't have an ISV - oh, and adaptations don't fix the problem...
                    Any ideas?
                    • bikerjim
                      • Feb 2008
                      • 1028
                      I would try a known working MAF if I were you. Failing that try another throttle body.
                      • will20v
                        • May 2007
                        • 391
                        its quite often a split breather hose under the inlet or a broken hidden one way valve. ive seen people scrap there cars because they cant solve it lol
                        • 1781cc
                          • Nov 2011
                          • 1253
                          I have 2 working MAFs and neither solve the problem, so much so when you disconnect the MAF it has no effect on it, its not a boost leak.
                          I will have to spend a day on it and just unscrew and screw everything on it. Might get a new PCV valve to start with though...
                          • Jenks
                            • 261
                            May be wrong but that might just mean you've got two knackered MAFs there. Have you tried either or both of them on a different car?
                            • 1781cc
                              • Nov 2011
                              • 1253
                              I dont have another car or know someone to test it out on, but they were new in boxes?
