Porsche 440cc Injectors any good on our cars?
  • s2_wot
    • Aug 2006
    • 2178
    I've been offered some Porsche injectors with bosch part number 0280156012
    Can they be used on our cars at RS2 power levels?
    Shane
  • Sleeper_Avant
    • 2372
    Porsche Part # 996-606-132-00
    Bosch Part # 0280-156-012
    Flow Rate: 41 LB - 430CC - @ 3 bar -
    Injector Style: Bosch EV6 (48.8MM) -
    Impedance: HIGH
    I would stick with what are known, these will have to have specific software mapped matey
    i do have a set of 440cc 0280 150 558`s that were sold to me as RS2 ones, but are the green top alternatives if you were interested
    hope this helps
    Sean
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
    • s2_wot
      • Aug 2006
      • 2178
      Thanks Sean
      Shane
        Originally posted by s2_wot
        I've been offered some Porsche injectors with bosch part number 0280156012 Can they be used on our cars at RS2 power levels?
        Supposedly Porsche GT3 injectors (so overkill for an RS2 turbo)
        Supposed specs:
        453cc @ 43.5 psi/3 Bar (standard), max. ~400hp
        480cc @ 49 psi/3.4 Bar, max. ~450hp
        555cc @ 65 psi/4.5 Bar, max. ~500hp
        600cc @ 76 psi/5.2 Bar max. ~550hp
        640cc @ 87 psi/6 Bar, max. ~600hp
        • prj
          • Mar 2010
          • 6308
          Supposed specs:
          These horsepower numbers have little in common with injector application on a 2.2T Audi engine...
            Now that you mention it, those numbers were for a V6 so yes they will be high for a 2.2L AAN/ABY/ADU.
            But do you think they are perfect match for an RS2 turbo? I think not.
            • prj
              • Mar 2010
              • 6308
              I don't know their spray pattern, but I have been using 440cc Volvo's and 510cc EV14's with the RS2 turbo.
              Not that it matters though. "Too big" does not exist anymore with modern injectors.
