ok so later this week the engine should be coming out as i have an oil leak which i believe is coming from the rear main seal.the clutch occasionaly slips too under load so its either worn out or oil is seeping on it,either way time for a replacement.
as i have no ramp id rather do it this way so then whilst its out i can replace other bits like steering gator,bomb etc
One thing which has been on this car since when i first owned it is the wobbly bottom pulley.when the car idles you can see it moving like its egg shaped...only a little though.Rev the engine and it runs straight as you would expect.
the car is due a cambelt change due to age not mileage so will be doing this at the same time.
could this wobble be due to the damper in it or even worse the crank nose being damaged etc?
