gt30
  • nip
    • Apr 2006
    • 1786
    • Home: United Kingdom Current: Abu Dhabi
    gt30
    what would the best housing be for lets say 500+ hp. Obviously it got more chance with a .84 but when will it give max spool , i like the .63 housing due to quicker spool
    but how much top end power would i lose .
    On each housing when would you get full spool at what rev, cheers for any advice
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    GT3076 0.63AR would hit 500hp or near....
    read and check Vasilis "enough with the upgrades" thread
    anyway with a GT30R the lagg does not exists... if you are off boost powerband just reduce one gear and flyyyyy
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      Not worth it the 0.82ar if you are after spool. The few extra up you get on a non ported head is making the lag too much. I'd stick with the 0.63ar and port the had if you haven't done so
      sent with Nokia 5110
      • Smiley
        • Jun 2005
        • 329
        slightly off-topic, but..
        stock K26 are quite cheap, what are they good for? >300hp?
        '93 Audi S2 Avant panthero black, 412.000km
        '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
        '93 Audi S4 C4 Avant, 260Tkm
        '88 Audi 100 Avant turbo 44Q
        '84 Audi 80 quattro tornado red
        • nip
          • Apr 2006
          • 1786
          Sounds like a .63, then pap, did u put ur .63 in urs if so what's the difference cheers
          • nip
            • Apr 2006
            • 1786
            Not sure smiley , if u can go for rs2 setup
            • Nik0las
              • 1345
              • Country: Bulgaria
              with 0.63 A/R you will have surge on high gears for sure
              • jade
                • Jan 2005
                • 1811
                Should not have surge problems with the gt 3076 the 3071 yes
                RS 2 580HP
                • nip
                  • Apr 2006
                  • 1786
                  What do mean by surge
                  • prj
                    • Mar 2010
                    • 6308
                    There will be surge. Depending on the VE of the engine, more or less.
                    But on standard cams 0.63 A/R on a 3076R is surge-o-rama. All the gain by the 0.63 A/R housing is pretty much negated by the fact that you have to limit the boost.
                    I don't see any point in a 0.63 A/R on this turbo either.
                    With 0.82 A/R you will hit full boost at 4100-4200 rpm, and this is exactly what you need to hit all the gears. In 1st gear you can rev to 7300 rpm and then swap to 2nd, and you will not have any boost lag.
                    In fact I don't see any gain on a GT30R and 0.63 A/R housing due to the way these cars are geared. In real life the 0.82 A/R driver will be faster all the time if he knows how to shift the gears right.
                    If you want reliable 500hp without the EGT's shooting through the roof, it's a pretty good idea to use the 0.82 A/R housing.
                    With the 0.63 A/R, you can get 500+ on a dyno, but by the end of 5th gear you will have very high EGT if you run this much boost all the time in real life...
                    • Nik0las
                      • 1345
                      • Country: Bulgaria
                      When turbo makes more boost than engine can take...
                      • prj
                        • Mar 2010
                        • 6308
                        And the compressor wheel goes from 100 000 RPM to 0 in an instant.
                        This destroys turbos quite fast if there is a lot of it for a long period of time.
                        • Rocco
                          • Aug 2007
                          • 6393
                          • Country: Spain
                          I'm having 650 egt degrees with my gt30r on full boost Dmitri.
                          • Sleeper_Avant
                            • 2372
                            to add my 2p,
                            .63 pointless, .82 much better solution and control and engine friendly
                            why people make duty cycle and capability of components towards the end of limits is beyond me,
                            for the OP`s needs id go .82 and 650cc/min or bigger but thats my choice and input
                            Sean.
                            1993 URS4 Avant Emerald Green 350+bhp
                            1991 Ford Sierra Sapphire 4x4 in Magenta
                            BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
                            • Sleeper_Avant
                              • 2372
                              Rocco, thats a very low EGT reading
