It is something vibrating starting with 3500 rpm until 4000 rpm.It is engine related not running gear because it does that in any gear,including stationary.It is aan stock opened and rebuild.Not needed bearings(0.05mm gaps),only a honing to get bores round again,new rings,head rebuild etc.Only converted to sm flywheel.Changed flywheel with another sm one from another engine that had no vibrations but problem still there.I imagined crank and fly wheel were not balanced,but it is not the only aan with sm flywheel without balancing.Could be front pulley?It is engines stock one.But it has no cracks,no visible play,runs perfect round.Vibration comes even when revs are getting down and pass that rpm area.It is not ignition or fuel related.
How should i explain vibration?it can be felt only in gas pedal and a little strange sound.Could be something auxiliary rotating part doing that?Pas pump,generator?
