Hesitation/power loss on 3B cured
  • dkw_dude
    • 555
    • Country: Norway
    Hi
    My 3B S2 have been hesitating and not been as fast as it should lately (not the only one on this forum).
    I have done the usual pressure testing+soap water splashing, had a small leak in the WGFV and replaced it, along with new O-rings on the injectors. This helped a little bit (some of the O-rings looked bad, should be replaced every now and then I guess), but the car was still hesitating and slow.
    Then I measured the ambient pressure sensor as in this thread http://www.s2forum.com/forum/showthr...ressure+sensor
    between pins 1 and 2 resistance was ~900 ohm, should have been around 1200 ohm (at sea level). I changed this component 3-4 months ago, so I took the old sensor which I have modified with a 1200 ohm resistor from pin 1 to 2 instead of the actual sensor circuit. And guess what, the car runs way better, close to what it should. The hesitation is more or less gone!
    I don't know if this goes for all 3B engines, as I have a "no name" chipset, mapped on another car whith same mods as I have, but it may be worth checking out.
    Cheers Leif-Helge
    Leif-Helge
    -91 S2 VEMS and Comp Turbo
    -12 B** 530XD Touring "S2 parts transporter, and daily driver"
  • afhgus
    • Aug 2004
    • 50
    intermitant power hesitation
    Hi guys
    Could this apply to RS2's? I have an intermittant power loss situation. Nothing shows up on a diagnostic test and I am desperate to find out what is causing it? Any ideas? Thanks in advance. Appreciate it
    Volcano black,134500 miles,standard,everyday transport, new rear discs, new door trims, replaced radiators x2, front/rear shocks(OE) + suspension bushes, recent alarm, undersealed, exhaust/head gasket, pulls like a train. big turbo whistle 315 hp
    • 91_S2
      • 612
      between pins 1 and 2 resistance was ~900 ohm, should have been around 1200 ohm (at sea level). Cheers Leif-Helge
      Leif-Helge,
      On our LHD cars, where is that thing? Drivers side or passenger side?
      • porkkis
        • 1994
        Inside passenger side a pillar.
        Afhgus, could be.
