How to reduce boost
  • blu_s2
    • 392
    How to reduce boost
    Although I've still not found the cause of my low boost at high rpm I have a more pressing need to reduce boost!
    Car goes in for repair work on Friday and I'd like to reduce the power in the car, just in case.
    Any BTDT for putting the car into, say, mechanical boost only without causing any problems for the car.
    Jim
  • jameswkr
    • 538
    Jim - easiest is just to disconnect your WGFV - you will then only get whatever the spring is set to ( .4 to .6 bar ). Plug back in and reset ECU or drive and wait for optimisation. Cheers James.
      Disconnect the WGFV - that will raise a fault code of course - but you will have mechanical boost limit at ~0.6bar
      Paul
        Spook bit of x-posting there James
        • jameswkr
          • 538
          Yes, hopefully Jim wont get the message in stereo...........................
          • blu_s2
            • 392
            cheers, thought that would work but wanted to check... so I disconnect the WGFV twice then
            Jim
            • porkkis
              • 1994
              If you don't want the fault code or the garage to just plug it back then put a by-pass hose in place of the wgfv from compressor housing to wastegate.
              Other methods are to disconnect a knock sensor, this will disable boost control as the ecu is in a limp mode.
              In 3B cars you may tell the ecu the engine is overheating and it does the same without fail codes. Actually this function is also in the ABY ECUs, but there is no wiring for it.
              • audiman
                • 4827
                So the body work is being sorted then?? And you dont trust the garage right! LOL
                Tom C - www.rcmr.co.uk
                Audi UR Quattro
                Audi 100 C3 2.0 5 cyl 115ps
                Audi B5 RS4 645ps 911nm
                • blu_s2
                  • 392
                  would I ever use the term monkeys etc when describing repairers in the presence of people like you Tom I thought I was being so diplomatc clearly I failed
                  Jim
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    I've got mine limited to 0.3 Bar. My head goes forward everytime i think the boost is about to come.
                    SS
