Tial waste gate
Did you not get my pm mate? I replied straight away, wondered why you didn't reply, I will send it again! -
No problem, also I need to know are you staying motronic or going standalone as i'm moving the engine loom out your engine bay tomorrow at some point.
paracute?
between you and stuart/se 30 I doubt scotland can keep up. Stuarts car isn't far off running, just odd's and ends that need finishing and a exhaust then it can be started and run in ready for mapping. That one should go bloody well so yours will be interesting to see.
More like wingsuit!
My project is years from completion, between working 100 hours a week and having a baby boy in the house means less than 5 hours a month for my 90
I'm in no hurry, all I have is time! If you have seen my thread on classic Audi u will know not much gets done!
Can't wait to see Stuart's machine up and outrunning!Leave a comment:
The link ecu sounds an interesting option after seeing damo's results with it. Jeff was saying if you want the engine bay you want then the stock loom wouldn't cut it in the looks department.Leave a comment:
[QUOTE=Acidburn;682788]No problem, also I need to know are you staying motronic or going standalone as i'm moving the engine loom out your engine bay tomorrow at some point.
I was thinking about useing a link stand alone ecu but I'm not sure.
Ill ring you in the morning about it.Leave a comment:
paracute?
between you and stuart/se 30 I doubt scotland can keep up. Stuarts car isn't far off running, just odd's and ends that need finishing and a exhaust then it can be started and run in ready for mapping. That one should go bloody well so yours will be interesting to see.Leave a comment:
One of my pals knows Martin ryland so If I ask him nicely I might get that one cheaper .thats the plan
back on topic, shop around John. prices from owen developments seemed uncompetitive compared to ebay. tho mailorder from inside the uk was appealing.
a 44 will do the job ehh?
http://www.ebay.co.uk/itm/Tial-44mm-...item3a627ac2cf
not sure about best spring?
Ps thanks for all your help Pete much apreseatedLeave a comment:
thats the plan
not sure about best spring?Leave a comment:
i got 60mm tial wg from america via ebay, real street performance.
was pretty dam cheap tho had to pay import tax.
worked out much cheaper than owen developments.Leave a comment:
Owen developments stock them with a range of springs to choose from.Leave a comment:
