changing the fuel filter
  • s2driveruk
    • 12696
    Ok, so after 163,000 miles I think its time to change this.
    Couple of questions though:
    1) am i likely to dump a load of petrol all over the drive?
    2) The car is 'homefried', will a fresh filter produce any odd fueling/pressure issues as it was upgraded on the original filter?
    3) How easy is it to change myself?
    4) Any idea on cost/partnumber
    Cheers guys!!!!
    David
    1992 3b S2 Coupe
  • martinjs
    • 3205
    David,
    its quite easy to do on the superior coupe , unlike the avant..lol
    I got mine from halfords believe it or not, think its the only part they have listed for the S2.
    just 1 banjo bolt each end to undo, both slightly different sizes so will only go on 1 way. You should get new copper washers with the filter.
    Crimp the line from the tank with a g-clamp and you shouldnt spill much fuel.
    dead easy.
    HTH
    martin
    • s2driveruk
      • 12696
      cheers Martin! didn't expect to be taking a walk to Halfords!!!
      David
      1992 3b S2 Coupe
      • Erikb
        • Jul 2004
        • 648
        It is pretty easy to do it yourself when you have a coupe, i believe it is more work when you have a avant.(took me half an hour) There will come a small amount of petrol out of the filter but not much. I dont think the performance will rise, only when the old filter is full with dirt(mine wasnt). I believe I paid around 20 euro at the stealer.
        kind regards,
        Erik de Bruijn
        Getting everything sorted out for my 5++ hp project
        • s2driveruk
          • 12696
          after 12 years on the car, i expect mine to be full of rubbish and restricting the flow. Will post some pics once I have changed it.
          Does anyone know if there is an inline oil/particulate filter for the turbo?
          Cheers,
          David
          1992 3b S2 Coupe
          • SteveH
            • 4460
            David, The main oil filter is used to filter oil to the turbo. Mark H added a small inline filter to his setup, ask him for details.
            91 Modded 3B
            14 A6 Avant Black Edition
            • Billman
              • 4129
              Any advice for a filter change on the Avant??
              Go Holset or Go RS4
