How suitable is this turbo for my S2?
RS2 turbo can deliver 360-370bhp at the redline and YES it can easily exceed 500Nm of torque in the midrange.
PaulPaul Nugent
hi all
Since this is my first post here I really have to say, that this is a great forum. Already found lots of helpful info here...
back to topic: I've also been looking at these 034efi turbos for quite a while and I was wondering if the K26-T3 hybrid they offer would be a good fit on my ABY engine. I'm planning to revise my engine sometime soon and therefore I'll also get a new turbo. Now my question is: Is it possible to use this K26-T3 without remapping the ecu (I'm still running oem ecu) or would that result in bad performance or a broken turbo? Because as far as I can see, this turbo should have less (or same) lag than the S2 turbo but a slightly better output on hi revs.
Thanks for any inputs!
regards from cold Switzerland,
MattComment
What are you sayn' about this turbo? What is the difference to the other
K26/T04E HIGH OUTPUT Hybrid Turbo
Here is the link http://www.034efi.com/catalog/produc...04ec905b62ccc8
There is the K26/T04E Hybrid and then the High Output Hybrid! Any infos here???
There is Also a RS2/Garret Replica turbo!
Here http://www.034efi.com/catalog/produc...products_id=75
How is this going to be instead of the KKK RS2?
ByeGo Holset or Go RS4Comment
