Rs2 Em
  • blu_s2
    • 392
    Rs2 Em
    Couple of questions for the tuners out there....
    Will an RS2 EM bolt straight up to a stock ABY turbo/downpipe?
    Will a remap be needed or will it behave on a stock or home fry ABY chipset?
    I assume no performance improvement would be had if all else remained stock.
    Jim
    Yes Jim - the RS2 EM does bolt straight up to the ABY head and stock K24 turbo and downpipe. I've never heard of any issues with that - other than the fun and games required to remove some of the EM studs. I'd say its less hassle to remove the entire head with manifolds attached than try and fight off the EM in situ.
    I doubt you'd feel any improvement with everything else stock - never quantified that myself. Its a good 'foundation' mod though if you are dabbling with thoughts of the dark side
    I also doubt there would be any significant gain just to be had from a chip tweak - as the flow limit shall be the amount of air that the stock turbo can deliver.
    • SteveH
      • 4460
      The RS2 EM is a direct replacement for the standard 3B/ABY manifold. You wont need to alter the downpipe or turbo fittings
      Your ECU wont know the difference either, so there is no need to be concerned about remapping. The upgrade will allow for better gas flow from the head, so a big turbo, injectors, intercooler, fuel pump, etc, etc will be needed to make the most of it
      91 Modded 3B
      14 A6 Avant Black Edition
        Jim - there is a trend here with you get replies in stereo this week.
        • blu_s2
          • 392
          cheers guys.
          Once my car is back out of the garage I need to strip the EM down as I 'think' there may be a small leak around there.
          If the EM is gone then I may move to RS2 to give me the option later of upgrades.
          Jim
          • martinjs
            • 3205
            Beware of the possibility of the studs snapping if you are removing the manifold jim.
            9 times out of ten the head will have to come off to get them out BTDT
            martin
