Poor warm idle stalling
  • SteveH
    • 4460
    I have a problem with my car at warm idle with it dropping revs really low and stalling. It's fine from cold and it only happens when the engine has started to warm up. I've also got a problem with the water temp feed to the clocks from the MFTS, so I'm wondering if the water temp signal has a direct interaction with the idle control? I think I have a dodgy sensor or the cabling needs attention.
    Anyone have any ideas what to look for or test?
    Cheers,
    Steve
    91 Modded 3B
    14 A6 Avant Black Edition
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    Bad MAF could also cause dodgy idling.
    1996 S2 ABY Silver
    • AndyP
      • 6049
      The MFTS does not feed the ECU, the sensor on the back of the head does that. I take it you've tried cleaning the ISV?
      • SteveH
        • 4460
        Thanks Andy.....so the lack of temp readout on the guage is just down to the MFTS or it's cabling. The ISV has been cleaned and it works fine when the car is started from cold. It's like the ISV isn't getting the right signal when the coolant is hot. The revs dip really low and the car stalls when stopping at junctions. If it's left running it idles fine. It must be something to do with the throttle closing and the ISV circuit not kicking in correctly. I can hear the TPS click when the throttle closes and I have tested the TPS signals and they are all fine.
        91 Modded 3B
          Click on the MAF, MFTS, ISV and Idle Switch labels in this diagram to help figure out your idling issue:
          • prj
            • Mar 2010
            • 6308
            Vacuum leak. This is exactly how it will behave if you have one.
            Pressure test it, then everything else
            • SteveH
              • 4460
              Cheers guys
              91 Modded 3B
              • andy10v
                • 5996
                3B ecu uses the MFTS. Are you 3B or converted to ABY?
                Sold ABY-stock
                • SteveH
                  • 4460
                  Still 3B at the moment, however the paln was to convert next week. I think I'll do the pin swap and see how she runs afterwards.
                  91 Modded 3B
