Chips for ABY
  • Gavin A
    • Nov 2012
    • 260
    Chips for ABY
    When looking for chips i have noticed a couple of people have mentioned if the car has a chip key/ immob.
    Does it make a difference if it has a factory immobiliser?
    Do any of the chip sets come with the sockets?
    Thanks.
  • spink
    • 4382
    Does it make a difference if it has a factory immobiliser?No
    Do any of the chip sets come with the sockets?sockets can be bought for pennies,its the soldering of the sockets onto the board that requires some skill
    • prj
      • Mar 2010
      • 6308
      Some chips for an immobilized car will not work in a non-immobilized ECU.
      Furthermore, immobilized chips in a different ECU will cause the ECU to de-sync from the immobilizer and will need to be re-adapted with VAG-COM unless a few checksums are corrected...
      Non-immobilized chips will work in all ECU's.
      • Gavin A
        • Nov 2012
        • 260
        Thanks for clearing that up.
        • Gavin A
          • Nov 2012
          • 260
          If i was to fit an exchange ECU to my car which is chipped, so the original immob ECU is gone - will it start?
          • prj
            • Mar 2010
            • 6308
            If the ECU is non-immo, yes.
