urs4 rs2 turbo lag
  • turboaudis4
    • May 2010
    • 25
    urs4 rs2 turbo lag
    hi guys i have a 92 s4 this summer i replaced the engine ( spun bearing) i installed a rs2 exh manifold& turbo . it also has a mtm +2 chipset it has a lot more lag than it did before the rs2 turbo/manifold when it boosts it feels more powerful . the quarter mile times are almost the same as the stock motor with the chipset . the cold side of the turbo doesnt look like the rs2 turbos i see the inlet is bolted on the tag says k24-7200. i have checked the cam timing the only thing changed was the shortblock/turbo/manifold what difference does a rs2 turbo& manifold on a urs4 normally make ? thanks dave
  • Acidburn
    • 13459
    It should make quite a difference. Do you know what its boosting to on the dash gauge? that will help people on here diagnose it.
    Apart from the manifold/turbo/chips, what else has been changed on the car? exhaust? injectors? fuel pump? intercooler?
    It should be a lot quicker on the rs2 turbo if its genuine than a k24, might be worth speaking with prj on here about his opinions on the mtm +2 chipset as it sounds like it might not be the best chips to get the max out the turbo, he should know and be able to advise.
    • Rusty
      • 18953
      As above, chipped RS2 should be a fair bit faster. My 30-60 mph times dropped from 2.9s to 2.4s even with the lag, when I went from a well running chipped OEM S2 to chipped RS2.
        IIRC one of the MTM RS2 chips is only about 340hp?
        Also where did you get the chip from? Perhaps the "MTM" chip isn't an MTM chip at all, a lot of crappy chips get labelled with a big tuners logos to sell them.
        • turboaudis4
          • May 2010
          • 25
          sorry i forgot it has an aftermarket exh syst no cats the chipset came from hoppen mtrspts all this was in car with old engine i think boost was 23-24 psi lag seems much worse than stock comes in about 3800-4000 rpm thanks dave
          • Rusty
            • 18953
            Assuming that there are no leaks, that the fuel is good and that you have a full RS2 setup, get some chips from a known source with known characteristics and see if it's any better.
            Post up where you're based.
            • turboaudis4
              • May 2010
              • 25
              i am in us new york state the chipset is a mtm +2 from hoppen motorsport when i built the shortblock i put scat rods in it what is the best chipset for this ? i have rs2 injectors to install was going to go with mtm +3 chipset i would like to hear about different chipsets that are out there this is not my dd i have a a6 avant tdi for that ! thanks dave
              • driftin jo
                • Sep 2007
                • 2222
                Wait, you haven't put the RS2 injectors in yet ? !!
                you can't run RS2 chips and turbo on standard injetors.
                • K Simmonds
                  • Dec 2007
                  • 7627
                  I think the problem here is the guy is using chips for a standard K24 equipped car with an RS2 turbo bolted on in it's place.
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
                  • prj
                    • Mar 2010
                    • 6308
                    Install the RS2 injectors right away. Or bigger ones.
                    You are right now running very lean due to the injectors maxing out, and you will destroy your motor if you continue running like this.
                    The stock chipset also explains why the boost comes in so late.
                    If you need proper software, then I can always help...
                    Full boost will come in at 3500-3600 in 3rd and it will be quite a bit more powerful too.
                    • rynaqui
                      • Mar 2012
                      • 2752
                      • Country: Malta
                      You definitely cannot run RS2 turbo properly with stock injectors and fuel pump..nowhere near enough.
                      Get those and a generic RS2 map and you should be fine..I think! With a normal map, there should not be too much torque for stock rods (hopefully)
                      1996 S2 ABY Silver
                      • prj
                        • Mar 2010
                        • 6308
                        Torque and stock rods is a myth, plus OP stated he has scat rods.
                        • rynaqui
                          • Mar 2012
                          • 2752
                          • Country: Malta
                          Would stock rods be able to handle RS2 turbo safely? What about Hybrid? Just curious, maybe one day
                          1996 S2 ABY Silver
                          • prj
                            • Mar 2010
                            • 6308
                            I've done 500hp and 600nm on stock rods. There is a dyno graph posted of another car on here that I mapped with 440hp and 610nm also on stock rods.
                            Knock bends the rods. Custom map and all is well.
                            • rynaqui
                              • Mar 2012
                              • 2752
                              • Country: Malta
                              Read about that on here, more at a low rpm I suppose. One day hopefully, I could get some proper work done on my car, thing is, I live in the middle of nowhere, getting the car mapped properly would be too difficult
                              1996 S2 ABY Silver
