diferent between 7a and 3b head
  • aronmatic2
    • 2129
    • Country: Hungary
    hi guys
    i have 7a head. can i install to my s2?
    what is the diferent between 3b and 7a. i only know about camshafts.
    what else?
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
  • PekkaS
    • May 2004
    • 81
    I swapped 7A manifold to my ABY and it required few new holes to fit water manifold (or water collector, as etka says). Also I had to make a place for hall-sender, but that´s not required when it comes to 3B.
      Turbo heads have sodium filled exhaust valves. The 7A doesn't.
      Pekka is correct about the hall sender mods (except on 3B).
      Paul
      • aronmatic2
        • 2129
        • Country: Hungary
        ok
        if i change the exhaust valves, i can install the head? that sounds good.
        thank you guys.
        • Albert
          • 1500
          • Country: Poland
          what would be the advantage for using 7A head than 3b/aby ?
          AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
          • porkkis
            • 1994
            Availability.
            • Floddy
              • Dec 2003
              • 222
              AFAIK the cooling canals (is that the correct term?) are different.
              Red cars are the fastest ones...
              - Team Irry -
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                It's normal for a turbo head to have larger cooling chambers. A 7A head may give more scope for porting and combustion chamber enlargement.
                Has anybody got any old 3B, ABY, 7A heads to section?
                SS
                • mcandmar
                  • Apr 2004
                  • 5118
                  I've had a chance to compare my 7A to an ABY head side by side, as said only the water manifold differs in that it has outlets from the head between each cyl, where as a 7A only has the one outlet in the middle of the head. And also the Hall sensor mount. Mount for the distributor is also there on an ABY with a little cover bolted over it. Other than that they are the same.
                  Mark.
                  P.S. 7A engines DO have sodium filled exhaust valves, not just the turbos.
                  Originally posted by aronmatic2
                  hi guys
                  what else?
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                  • aronmatic2
                    • 2129
                    • Country: Hungary
                    i have a 7a head in my garage. i have a 3b head on my car with wery bad porting and polishing. we want to port and polish the 7a head, change the valves for srick cooled valves.and when we have done, change the head and the car not going to stay for a week or two.
                    my car going very nice. what you guys think about low compression engine.
                    i have 9. what boost is recommended.
                    my mods:
                    tt pistons
                    factory s2 conecting rods
                    rs2 injectors,ecu
                    11,5mm lift camshaft
                    home made EM
                    s4 IM
                    lancia exhaust valves
                    kkk k26/27 turbo
                    large cooler
                    s6 6 gang trans
                    i am planing to buy a garrett gt30r
                    • Beetie
                      • Oct 2003
                      • 1517
                      my mods:
                      tt pistons
                      rs2 injectors,ecu
                      home made EM
                      s4 IM
                      kkk k26/27 turbo
                      large cooler
                      s6 6 gang trans
                      Best speak to Mihnea, he can give you alot of advice for the turbo spec....
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        Here's an extract from the 7A Manual to show that the exhaust valves are sodium filled.
                        SS
                        • aronmatic2
                          • 2129
                          • Country: Hungary
                          thank you.
                          anyway, i will change the valves because i have them.
                          another thing. how can i installk the water collector?
                          do i need it?
                            7A exhaust valves are different from 20VT exhaust valves - at least they were last time I looked on the family album.
                            • AnLe
                              • Dec 2003
                              • 291
                              Yes they are, they have different part numbers.. I have witnessed +140hp per cylinder powers with these na-valves, no prob.
                              please keep in mind that nm/7a/gtigolf has very good power per litre ratio considering the mid 80:s.
                              It is allways assumed that turboparts are better than na versions, but how is this: turbo has around 9 compratio, na has 10.5 and with 0.7 standard boost pressure the turbo engine is "9.7" versus 10.5 of na engine and factory margins the 7a valves should be better..
