Need 1.2mm head gasket
  • Pat D
    • Dec 2011
    • 748
    • Country: Australia
    Does anyone know where to find a thinner 1.2mm head gasket?
    My comp worked out to be 8.3:1 with a 1.65mm gasket and a 1.2mm will bring it up to 8.5:1
    ABY S2 stroker (work in progress)
    B5 1.8T quattro
    B4 2.3 (decommissioned)
  • Nuno Cristiano
    • Aug 2010
    • 421
    • Country: Portugal
    What bore in block engine you use?
    .: MINI Cooper D 08' :.
    .: Audi Coupe Quattro 20V 91' :.
    .: Audi Porsche RS2 95' :.
    • Pat D
      • Dec 2011
      • 748
      82.5mm bore ACV block. I'm taking it back to the machine shop to skim the deck instead. Piston clearance is .254mm below deck at TDC and I want .65mm above the deck.
      B5 1.8T quattro
