I have been offered a K26/27 it has a standard K26 Shaft and exhaust housing
Has a K27 Compressor housing which has been machined for a larger K27 Wheel.
Comp Wheel measures 73mm at the base (for torque)
Diameter of top of wheel (length of blades) is 47mm (for horsepower)
Height from bottom of wheel base to top of the start of wheel blades is about 5mm (for torque)
I am told the car it was on the mapping wasn't finalized, as it was tuned for a K26/K27 Hybrid with a much smaller Comp Wheel (About the size of an RS2 Comp Wheel).
He said he got Full Boost 1.7bar at about 3800RPM with standard AAN Camshafts and stock internals.
He said his car was much stronger in high RPM with this turbo vs the RS2 turbo.
So now I need some help with a map if I buy this turbo.
I am looking for a map to suit this turbo on my S2.
I will also be fitting RS2 440cc injectors and a Wagner or RS2 exhaust manifold, with a 76mm DP and exhaust system and at a later stage a larger intercooler.
Any help is welcome
orsum
Any help is welcome
orsum
