220mm block with 92.8 crank
  • mac2226
    • Jun 2008
    • 1289
    Hi just wondering has any one gone down this route of short block 220 with stroker crank 92.8 and what sort of rod sizes is best match to crank
    do you have a 92.8 crank? They are pretty rare!
    Stock rod ratio is 1.666 for reference, but you would need a lower ratio. There are other aspects to consider first such as compression ratio, piston crown thickness etc that will determine your rod length. I guess you want to use stock pistons? Anyhow, I don't think there is an off the shelf rod option for the 92.8mm crank AFAIK due to their rarity, could be wrong though
