fuel pump problem
  • madtaz
    • Dec 2012
    • 2
    fuel pump problem
    hi can anyone help went to start my 2.3 20v coupe e today she started her up after 10 mins the fuel pump become very loud then car become very lumpy at tick over is the fuel pump on its way out or is there fuel filter blocking up any help i can get will be great help thanks stef
  • recall
    • Jun 2010
    • 336
    Change the fuel filter first.
    easiest. cheapest.
    Boost is what makes the world go round.......!
      Hi Stef,
      As above, try changing the filter, if that doesn't help then the pump is probably on its way out. Let me know if you need one I have one here
      • madtaz
        • Dec 2012
        • 2
        thanks to both of you fitting new 1 today if i need a pump i let u knw error404
