K24 bearing options
  • s2driveruk
    • 12696
    K24 bearing options
    Hi,
    Anyone know if there are any better options for bearings than the standard ones (e.g roller or ceramic etc)? Just wondered if anything would help squeeze some more performance out of the unit or is it best to stick with stock and accept that the K24 has a limit?
    Thanks,
    David
    1992 3b S2 Coupe
    The problem with ceramic and rollers are they dont last as long but give cracking spool up time.
    The other problem is the the bearing part of the turbo will be garrett based therefore you'd need adapted water and oil lines.
    For the price you'd pay to get that lot done i'd get an RS2 or maybe Mihnea custom turbo which has seemed to disappeared.
    • s2driveruk
      • 12696
      Cheers Jamo budget won't stretch to anything exotic right now just wondered if I could do anything that way.
      RS2 or hybrid is on the xmas list along with a ton of other stuff
      David
      1992 3b S2 Coupe
