as my pipe dream has started to take shape i need to look at where the power will come from
just a quick apology to prj and urs4boy for stunting there discussion last time but didn't want the thread to deviate to far from updates on the build.
so any help from you guys here will be freakin awesome
so 600hp aim around 5750rpm to 6800rpm
2.5 dag dag stroker
garret gt 35 or 40
possibly a holset if can pull one from a lorry breaker and rebuild or evan a boat yard as used on perkins and volvo penta engines i think.
dta ecu as my friend used these on his 8v corado turbo and has a good grasp of software
my issue is the finer points. i would like to complete as much of this work as possible.
Due to leaving my job at a garage after only a year to move into sales i have been branded an office boy by my mates. I could realy do with proving a point.
so i shall be looking to find what cam set up to use as really do not want to incur the costs of high rpm 7200 is fine with an uprated dsy box. I am hoping by keeping stockish limit i could use 7a/nm of a selection of.
also what crank and block would be best for this
i currently have a chipped 3b if any parts not if any parts other than the head would be usable with build
there have been quite a few references to rod length and piston profiles so when i have had the time to read through i will question this then.
cheers in advance
2.5 dag dag stroker
garret gt 35 or 40
cheers in advance
