Hi all,
Quick question, has anyone with EV14 injectors had leaking lower O rings?
Tension on them is perfect, but I already noticed on mounting them (more than a year ago) that the o-ring barely goes in the head, deptwise that is. Looking at the photo comparing it to an OEM one that seems normal however.
Are there any better O-rings available for them? Maybe a bit fatter?
This one is the worst, another one is a bit less, and the other 3 are only very slighty black and moist around the injector. They've all been like those 3 for a while now, but I've done a weekend in germany with often long max boost at 250+ so they've had some work to do and now finally 2 are leaking strong.
Thanks for the input.
0-200km/h 9sec
7
