K24 7000 to K24 7200
  • Guslotti
    • Mar 2011
    • 182
    • Home: Italy Current: Brazil
    Hi,
    I have my S2 (ABY engine) stock and mapped to run about 280hp. I need to know if I can change the stock exhaust manifold and K24 7000 for a RS2 exhaust manifold and K24 7200 with no changes in another parts or software. Is it possible?
  • Acidburn
    • 13459
    you will need injectors and software to run that properly.
    • Guslotti
      • Mar 2011
      • 182
      and just the exhaust manifold?
      • Acidburn
        • 13459
        you will definately need a different exhaust manifold if you want the best out of that turbo, stock manifold is not good enough and will cause issue's. Only time i've heard of a stock manifold being used for around 350+ is when jp ported one from what I remember.
        • Guslotti
          • Mar 2011
          • 182
          but is it necessary a remap just to change for a RS2 exhaust manifold?
          • my2000apb
            • Jul 2010
            • 637
            no remap required
            you can also run the rs2 turbo on your current setup, its jsut wont be rung out
            BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
            DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
            • diogocartier
              • Jan 2012
              • 151
              • Country: Brazil
              Guslotti,
              I'll do the same thing on my ABY with Kiko, from Petrópolis, during the next month.
              I'll remap, change the Fuel Injectors, and install a new exhaust (3").
              Unfortunately I couldn't find the ABU Exhaust manifold.
              Are you changing the Turbo and the Manifold or just the Manifold?
              Best regards,
              Diogo.
              • david
                • Oct 2008
                • 1268
                Hi,
                this is what you need if you want to run an rs2 spec.
                RS2 TURBO
                RS2 IC OR BETTER(cheers Rusty)
                RS2 FUEL PUMP OR BETTER (cheers rynaqui)
                RS2 MANIFOLD
                3" DP
                RS2 INJECTORS OR BETTER
                MODIFIED ABY ECU OR RS2 ECU WITH HIGH BOOST CHIPS
                [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
                RS2 VOLCANO BLACK] soon to be broken to bits
                • rynaqui
                  • Mar 2012
                  • 2752
                  • Country: Malta
                  And bigger fuel pump (RS2 or other)
                  1996 S2 ABY Silver
                  • Drummer87
                    • Oct 2009
                    • 1644
                    • Home: United Kingdom Current: Scotland
                    fuel pump for sale section
                    • Guslotti
                      • Mar 2011
                      • 182
                      Originally posted by diogocartier
                      Guslotti,
                      Best regards,
                      Diogo.
                      I have both of them. I'm thinking yet, but if I don't need a remap, I will install the manifold and K24 7200.
                      • Guslotti
                        • Mar 2011
                        • 182
                        RS2 TURBO
                        RS2 MANIFOLD
                        3" DP
                        Hi,
                        I'm not looking for a RS2 spec, I just want to know if with my current spec and RS2 exhaust manifold and turbo I can have some improvement with no remap.
                        • Guslotti
                          • Mar 2011
                          • 182
                          Originally posted by my2000apb
                          no remap required
                          Hi,
                          I know that with this mod I can't target a RS2 results. I doubt is with this mod I will have a better result with no remap. My ECU is remap to run about 280HP... with this manifold and turbo I can get a better performance with no engine problem?
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            It is pointless and a waste of money fitting an RS2 turbo and not remapping, if your current EM is cracked then replacement with an RS2 item would make some sense.
                            1990 B3 2.0 80 quattro.
                            1992 C4 2.8 Avant quattro
                            1994 MTM RS2.
                            1998 B5 TDI quattro Sport.
                            2000 B5 TQS.
                            • Drummer87
                              • Oct 2009
                              • 1644
                              Or exchange the turbo and manifold off my s2
