I still have problems with starting and turning off my engine. When I turn the key you can here the starter running, the engine start, but it is not the normal starting sound (really hard to explain what the problem is) sometimes you cant even here the car running, but it is on.
Also when I turn off the engine it makes a strange noise and the car shakes for second , it just sounds if it is still running on some cylinders.
Besides that it is still not running great in high revs, it makes a strange noise.
I did several boost leak test, but that isnt it. already changed a lot of stuff:
-wgfv
-dumb valve
-airfilter
-spark plugs
-fuel filter
Maybe some other injectors will solve the problem?
Or can it be that the engine is falling apart?
-wgfv
-dumb valve
-airfilter
-spark plugs
-fuel filter
