Another thread on hesitation..............
I've read through the other posts and tried just about everything to resolve this issue so before I go any further, just thought I'd check with you guys to see what the next step should be.
The car is a UR Quattro with an RR (3B) engine which has been ugraded to RS2 spec. by Dialynx and it should be running circa 360BHP. Initially it was showing no faults in the motronic memory but it ran like a dog. After pressure testing the MAF to turbo hose with Andy P, I replaced several components as listed below:
1. Air filter changed
2. Spark plugs changed and gap checked
3. MAF to Turbo hose changed due to split
4. WGF valve changed - small leak
5. Wastegate diaphragm OK
6. Air circulation valve OK
7. Vacuum lines on Inlet manifold changed
8. Dizzy cap and rotor arm replaced due to oil in cap and worn contacts.
9. Engine coolant temperature sender
10. ISV solenoid checked using auto test mode
11. Injectors checked using auto test mode
The car goes relatively well in 1st and 2nd with a hint of hesitation at the top end of 3rd, but it is really noticeable in 4th as the car does not want to go much over 4000rpm on WOT and the same again in 5th.
I checked the codes again today and it is not picking up anything.
So I'm running out of ideas, although I did think about doing the following:
1. New injector seals + general service as I noticed one of the end caps is cracked
2. Change the fuel pump as the pump is the original UR one
3. HT leads
Any othe rideas?
3. HT leads
Any othe rideas?
