Fusebox seal available ? Part no. ?
  • QuattroFever
    • May 2006
    • 1360
    Anyone know if it's available or a suitable replacement?
    Pics in the stealers don't have it illustrated as even having a seal.
    Thanks in advance.
    Volcano ABY coupe
    Ant
  • epic
    • 1317
    Lid seal or main box?
    The lid seems to come with the seal 8A0941801. S/H lid with seal would be easy to get.
    Main Box shows not seal but Sikaflex etc would work fine here.
    • benntenn67
      • Jun 2009
      • 859
      Box to scuttle seal - looks same stuff as coupe rear lamp cluster cord seal
      Audi S2 Coupe 1995
      VW Passat GL5 (hatch) 1986
      Carrera Subway 8
      • Drummer87
        • Oct 2009
        • 1644
        • Home: United Kingdom Current: Scotland
        Dum dum, ring Audi for a few metres
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          Probably on Back Order and costs a million billion
          1996 S2 ABY Silver
          • benntenn67
            • Jun 2009
            • 859
            ... Actually not that bad in Audi terms - £40 for 4 metres & still available
            Audi S2 Coupe 1995
            Carrera Subway 8
            • rynaqui
              • Mar 2012
              • 2752
              • Country: Malta
              Good to hear
              1996 S2 ABY Silver
              • Drummer87
                • Oct 2009
                • 1644
                Maybe if you make a thread titled spare dum dum, people will have some left over.
                • rynaqui
                  • Mar 2012
                  • 2752
                  • Country: Malta
                  Didn't know it was called dum dum, cheers
                  1996 S2 ABY Silver
                  • benntenn67
                    • Jun 2009
                    • 859
                    I have a roll of it
                    Audi S2 Coupe 1995
                    Carrera Subway 8
                    • Pat D
                      • Dec 2011
                      • 748
                      • Country: Australia
                      I use that non hardening window sealant that annoys the hell out of you because it gets everywhere, but what I do is put a bead down and then place a really thin plastic sheet over it so it doesn't actually make contact with the other mating surface and makes for an easy non messy removal if need be, but is thin enough to allow the bead to spread and form a good seal. I noticed some fittings such as the trim pieces bolted to the side of the car are done this way by Audi and I just copied that idea when putting them back on.
                      The plastic sheet I used was flimsy cheap 2 dollar plastic drop sheet stuff you can get from hardware stores, etc. HTH
                      ABY S2 stroker (work in progress)
                      B5 1.8T quattro
                      B4 2.3 (decommissioned)
                      • Drummer87
                        • Oct 2009
                        • 1644
                        For the rear lights I used tiger sealant as recommended by Pete. Done the job.
                        Woap this is my 1000th's post!! I'm an extremist
                        • QuattroFever
                          • May 2006
                          • 1360
                          Yer, was the fusebox to scuttle seal. Dum dum it is then
                          Volcano ABY coupe
                          Ant
