oil pressure gauge issues
  • bernsaudi
    • Feb 2007
    • 592
    My rad split today so I took it out. My oil pressure gauge is always showing 5 bar. If i disconnect the wires it still shows 5 bar. I see a single wire sender and a double wire sender(photo) can anyone tell me if this wiring is right? It should be as it has a cap on the single wire. Before I put my rad back in I would hope to get this gauge working again. Any help appreciated...Ta!
    No photo.
    A constant oil pressure gauge reading of 5 Bar is the tell-tale sign that the gauge sender is FUBAR'd. Here is some oil pressure gauge info to read:
    • bernsaudi
      • Feb 2007
      • 592
      Ha! Hadnt quite got the photo on! It's on now!
      2 senders, one conduit with 3 wires, one goes to a single sender one goes to a double. I will have a look at the link, thanks!
      • irishs2
        • Apr 2009
        • 2455
        This is how mine was wired
        Eric
        95 S2 Avant under rebuild.
        • bernsaudi
          • Feb 2007
          • 592
          Anyone got a spare analogue sender , am I right in thinking I should be able to get it to drop if I short the 2 wires?
            There is so much rust and corrosion on your engine and accessories, e.g. the after-run pump is not looking happy, I suspect the sender might still be good but the connections are corroded, etc. I would start by removing the sender with the two wires and cleaning everything up, including the mating surface on the block and the two male and female spade connections.
            After-run pump info: http://forums.quattroworld.com/s4s6/msgs/21503.phtml
            • bernsaudi
              • Feb 2007
              • 592
              It is a bit horrible in there, my rad has been weeping for a while.
              Does anyone know what resisance readings I hould be getting off the double pole sender if I put a multimeter across it during running or engine off?
