UrS Fuel System: From the Tank to Injectors and Back Again
    Our C4 UrS sedans and avants (and S2s and RS2s) have three fuel lines, as shown in the schematic below (note the hyperlinks to more info are underlined)
    1. A high pressure feed line from the fuel tank and 091G pump to the fuel filter, fuel rail and injectors and fuel pressure regulator,
    2. A low pressure returnline from the fuel pressure regulator back to the fuel tank and
    3. A fuel vapour line to the fuel emissions canister.
    Here is the C4 fuel tank and inlet parts, note Item 6 the retaining ring used to hold the top of the fuel sender plate tight to the fuel tank.
    To ensure no fuel or vapour leaks, there is a large O-ring that sits between the top of the tank and the bottom of the C4 fuel lever sender plate (Item 4 here):
    Here is an example C4 fuel sender coming out of the tank:
    Here are the C4 fuel lines:
    Here are the 3B and ABY fuel lines:
    At this point in their lives, you might want to check your fuel lines and, as need be, use : Fred Munro's Fuel Line Maintenance DIY pdf
    Better safe than sorry.
    Thanks Dave, might be just me, but the Fred link doesn't work ?
    • audinut
      • Jul 2009
      • 2195
      didnt work for me either
      NOT a car dealer! just an S2/RS2 enthusiast
        It was a double quotation mark issue resulting from processing the original Kawf html document through WORD for vBulletin. Should all be fixed now.
