Sport quattro head washers for ARP head studs
  • Rusty
    • 18953
    Just thinking about these and found this thread on a search. Sounds like the SQ washers are NLA, so I wanted to know what alternatives there are and if there is an off the shelf solution? If not then dimension of the SQ washers would be most useful and I'll get a quote for a batch
    It was only a matter of time wasn't it. I'm sure there will be an off-the-shelf solution somerwhere if we get some dims and material. I have a couple of fastener specialists down the road that I deal with through work if that's any help
    Anyways, I'll take a set to keep in stock for futures if it ends up that you need to get some made Andy
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      Why are needed?
        Otherwise the normal ARP washers sink into the soft aluminium head
        • URquattroGus
          • Aug 2007
          • 547
          You can use the standard washers with the arp's. The real issue is that the ones that arp supply are tiny, and do sink in. The standard ones are better, and the sq ones are a belt and braces ideal approach. This is my understanding after looking into it when my engine was built up.
          Angus
          (1984 ur quattro)
          • Rusty
            • 18953
            Anyone got a stock bolt to measure the captive washer?
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              i have ARP kit with Sport quattro washers
              i bought everything from a forum member sometime ago...
              • Rusty
                • 18953
                Well done... Washer size?
                • driftin jo
                  • Sep 2007
                  • 2222
                  the standard washer is 20.7mm dia by 4.4mm thick
                  • Christophski
                    • 3632
                    The standard washers don't fit. I tried it. I know people advise not to but I used the arp ones. Are they really that bad?
                    • Rocco
                      • Aug 2007
                      • 6393
                      • Country: Spain
                      I don't think so,I'm running Arp head stud kit for 4 years with RS2 and k26/27. Turbos.
                      Never had a problem
                      • Christophski
                        • 3632
                        Glad to hear it. I have heard the stories of the washers sinking but have also heard of them being ok... Wonder why some ruin and some don't???
                          Never had a problem
                          How do you know you've never had a problem? you only notice this after you you remove the ARP if you need to remove the head.
                          People can have this problem and not know about it as the head has been bolted down and it's never taken off again
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            We did this on mine and Tonks did not see any issues with the ARP bolts and washers. That was 100K kms after my second engine rebuild
                            • Rocco
                              • Aug 2007
                              • 6393
                              • Country: Spain
                              i dont know, i only did the torque and re-torque some kms later as they suggested me.
                              and i have not opened again...i only know that still works perfectly.
