3B, ABY and ADU (maybe RR) intake tract schematic
    Will this help to discuss where boost leaks can occur on the 3B, ABY and ADU (maybe RR) intake tract? (Colours didn't quite turn out as planned) (sorry)
  • rj scotty
    • May 2006
    • 2195
    Nice one
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
    • Drummer87
      • Oct 2009
      • 1644
      • Home: United Kingdom Current: Scotland
      Thanks Dude your a legend
        Here is another copy, maybe the resolution on this one will be better:
          It is better.
          Thanks, you're creating a fantastic resorce for everyone running an I5.
          Kind regards.
            Originally posted by macspring
            It is better. Thanks, you're creating a fantastic resorce for everyone running an I5. Kind regards.
            Thanks. The "funny" thing is I haven't done the same thing for the AAN (yet).
            All I had was this diagram (which doesn't translate that well to 3B/ABY/ADU):
              I didn't want the AAN boys to feel left out so I did this (more to come)
                When you guys do a boost test on your 3B/ABY/ADUs, do you normally put the pressurizing bung in Hose 12 at the turbo discharge end and plug off hoses 22 and 25 at the Throttle Body? What is Item 25 after the corrugated hose 15 (which we can the Michelin Man on the AAN) going to the throttlebody, after the cross-over tube/cross member? Item 25 seems to be 3B only with something different for the ABY (and ADU). Yes? No?
