New Engine Break-in quandry
  • DFrosty
    • May 2011
    • 182
    Hello Gents
    I've been reading up on MotoMan's "How To Break In Your Engine For More Power & Less Wear !" and would like some of your actual and first-hand observations if you used this method....
    90q 20v track car
    7AT to S2 spec
    - built bottom end
    - built head
    Here's my quandry:
    Getting close to engine reassembly and 1st start-up. I've spent a lot of money on this part of the build and would like to follow the specific steps myself because I am **** like that. Now if 034 has to do the tuning on the dyno, which is what I presume, how do I do the break in steps before 034 does tuning if it will be running 'crappy' due to ecu in stock mapping??
    Thanks
  • terrybullwon
    • Mar 2006
    • 8782
    Trailer?
    And let them run it in on the dyno?
    Chef
    • LSG
      • May 2010
      • 897
      Also you realy need to put a cheap oil in it so all things bed in nicely. I no it sound stupid but mineral oil will let piston rings ect bed in quickly.You only need to run the motor in for say 500 miles. If you put a good oil in your engine before its run in your rings will not bed in and the engine may glaze the bore which will make it smoke
