Under the throttle body end of the intake manifold on an AAN (similar hose on a 3B/ABY/ADU), there is a "Tee" hose that is the connection to the N80 evaporative emissions control system and the positive crankcase ventilation system. Because the "Tee" hose us upstream of the one-way PCV valve, a split in the hose = a boost leak.
Thanks to AudiHeel/Goheels for the base photo. (Labeled version will be added to the PCV and N80 posts AND a revised boost pressure testing post)
