Rs2 conversion checklist
  • andyg plym
    • Nov 2006
    • 4646
    There seems to be a few debates on here over the years about what is needed to go rs2 spec, I have the following:
    Rs2 turbo
    Rs2 exhaust manifold
    Rs2 inter cooler
    Rs2 air box
    Rs2 injectors
    R201 resistor mod in the ecu
    Rs2 chips ( spinks in my case )
    Exhaust ( 3" from turbo back only 1 silencer on mine )
    So, what am I missing? Some people add fuel pump, fpr valve etc
    Others say not necessary
    What do you all think ? Any btdt experiences ? Will mine run better if fuel pump and pressure valve fitted ?
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    You need at least RS pump or better.
    Your 4 bar fpr is fine for custom tuning.
    RS intercooler is necessary too.
    • andyg plym
      • Nov 2006
      • 4646
      Thanks rocco you just reminded me, I do have one already fitted! Cheers !
      • Rusty
        • 18953
        I fitted the FPR as the chips were designed for it but a custom tune can use either, as Rocco says. It's only 5% difference in pressure so arguably a bit pointless but there we go
        Exhaust cam and cam belt pulley.are the remaining items.
        • AndyP
          • 6049
          Waterpump & cambelt
          • John B
            • Apr 2008
            • 926
            It all depends on whether you want to stay at RS2 spec or go beyond. The RS2 fuel pump is ok but may be tired if you have used kit. If you have new and want to stay at that spec RS2 is fine but if used, I would go for a beefier pump. I know you have new injectors as you bought them from me so no worries there. HTH
            2001 996 C4 - Being renovated
            • John B
              • Apr 2008
              • 926
              ....oh yes RS2 IC is necessary but I went for a Wagner strictly you will need ADU cams but I have stayed with ABY ones....up to you.
              • simon20vq
                • Dec 2010
                • 1379
                RS2 fuel pump for sure IMO, I had a slight splutter and since changing the standard pump things have been alot better.
