RS2 Factory Boost pressure
  • wowow
    • 123
    • Country: Hong Kong
    #31
    So, according prj, the RS2 does reach 1.4 and then taper to 0.9. My questions are : 1/. will I see this with my gauge ( going to 1.4 for a short while and then drop to 0.9 ), and 2/. how soon will it drop to 0.9 ? a few seconds, or until rpm goes up to xxxx ? Pardon me for repeating the questions as I cannot come to a certain conclusion from all these info presented.
    ________________
    RS2-95
    • wowow
      • 123
      #32
      prj, do you have a boost chart on the RS2, like the one you shown on an ANN above ?
      ________________
      RS2-95
      • driftin jo
        • Sep 2007
        • 2222
        See post 12
        • asperilla
          • Dec 2012
          • 21
          • Country: South Africa
          #34
          Originally posted by driftin jo
          See post 12
          Tx. do you guys have a chart for the S2 /AAN ur-S4/S6?
          • asperilla
            • Dec 2012
            • 21
            #35
            Originally posted by UrS4boy
            I would say 1.4 Bar (20.3 psi) relative boost is low(ish) for a stock RS2 with a 3.0 Bar MAP sensor in the ECU. Stock ABY and AAN is about 17 psi (1.19 Bar) peak boost (relative, 2.2 Bar absolute). RS2 should probably be closer to 22 psi (1.5 Bar). You might have small boost leak.
            Regardless, you might want to sort out the boost leak and then consider chipping your RS2 ECU with a good aftermarket chip set. I run a chipped ECU (MRC Stage 3) with a 3.0 Bar MAP and RS2 turbo, RS2 exhaust manifold, RS2 exhaust cam, RS2 injectors and RS2 MAF, and regularly get 27 psi (1.86 Bar) relative boost. This equates to about 360 crank HP (289 wheel HP).
            Where can i get a citation for this?
            • prj
              • Mar 2010
              • 6308
              UrS6:
              Code:
              RPM:   OB:    Std:
              1800   1.04   1.04
              2000   1.01   1.01
              2200   0.99   0.99
              2500   1.03   1.03
              3000   1.03   0.98
              3500   1.03   0.90
              4000   1.03   0.80
              4500   1.07   0.74
              5000   1.07   0.72
              5500   0.97   0.72
              6000   0.86   0.65
              6500   0.80   0.57
              7000   0.67   0.51
              There is temperature compensation on top of that - a little bit more when hot, a little bit less when cold.
              • wowow
                • 123
                #37
                I recently replace all my hoses and got rid of all leaks. Peak boost recorded 1.6-1.7 on the road, though not pushing hard enough. It feels like it could get up another 0.1
                ________________
                RS2-95
                  #38
                  Consider getting it chipped by PRJ, but replace all of the boost hoses with new or better still black coloured silicone hoses, and the vacuum hoses and their connectors before asking PRJ to chip it, and you should be an even happier RS2 owner.
