My turbo has eaten something!
  • Colesy
    • Feb 2009
    • 2980
    Was in the process of putting everything back together and noticed strange iron filings in the MAF-Turbo hose. Had a feel of the turbine and something didn't feel quite right so got a mirror and:
    Luckily I've been collecting turbos recently and have a refurbished RS2 ready to fit.
    But can't help but think that this might have reduced the resale value a bit.
    Won't be getting back on the road today either, any tips for changing the turbos over? And does anyone have an idea as to what might have caused this? I fear some careless **** might be responsible
    Wtf!!!!!!!!!!!!!!
    • david
      • Oct 2008
      • 1268
      PIECE OF MAF?
      [SIGPIC][SIGPIC]/SIGPIC]92 3B pearl white=gone back home to Germany,probably in bits and pieces
      RS2 VOLCANO BLACK] soon to be broken to bits
      • prj
        • Mar 2010
        • 6308
        Agree, piece of maf missing?
        Looks like a severe case of the munchies.
        • Sonic
          • Jul 2006
          • 5514
          S2Forum.com Administrator
          • GazzaG60
            • 4133
            that's a proper set of cut down blades.
            surprised the casings not fooked.
            looks like its had a rough round file on it.
            ives seen some bad second hand units. best to get it checked before fitting if you do another. the pitfalls of turbos I suppose.
            im sure better turbo experts will help here give you the lowdown on it
            • mcandmar
              • Apr 2004
              • 5118
              wow. More worrying question, whatever it was, where is it now?
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • GazzaG60
                • 4133
                a plasic maff does this.
                wow.
                • Colesy
                  • Feb 2009
                  • 2980
                  I can't find any sign of bits of MAF missing although the mesh is a bit bent so something could have gone through. I've probably had 3 MAF's fitted since I last inspected the turbo though so could be from any of them.
                  Hopefully I'll find more clues when I get the turbo off.
                  • Acidburn
                    • 13459
                    same thing with the turbo that was on the engine in the s2 cab originally, the blades looked like this. Apparently it still boosted fine just made a bit more noise.
                    You will probably find the engine has injested something and some marks on the pistons and head face around the valves
                      Billet o'clock
                      • Sleeper_Avant
                        • 2372
                        i used to see this regular with Subaru, Skyline and Evo`s that run the green HKS mushroom filters that disintegrate internaly!
                        • PeteRR
                          • 1326
                          Similar thing happened to my old 10V quattro
                          I found a small metal disc in the housing that presumably did the damage, but to this day I still don't know where it came from
                          • Colesy
                            • Feb 2009
                            • 2980
                            Have been making some progress with taking the turbo off but am stuck all the studs and bolts have come undone apart from one EM-Turbo stud that is stuck in the EM. The nut has come off but I haven't got enough room between the body and the inner wheel to slip it off:
                            I've tried jacking the engine up but this doesn't open up quite enough space. Any tips?
                            • irishs2
                              • Apr 2009
                              • 2455
                              I had similar trouble, but I had my front crossmember off, so the front snub could lift up , so jacking the engine up a little did it for me
                              Eric
                              95 S2 Avant under rebuild.
