Compression test results...
    I've just done a compression test on the car and the results are:-
    1. 10
    2. 10
    3. 10
    4. 8.75
    5. 10.5
    Comments please...
  • driftin jo
    • Sep 2007
    • 2222
    There is the possible cause of your lumpy idle
      Yup. And maybe my puff on startup.
      Next step is to check the ARPs and make sure they're still torqued up properly. Other than that, I'll just have to live with it until it gets worse...
      I also have some new lifters to go in but as the engine is quiet normally (one or two stick after a proper thrash), I doubt that this will make any difference to anything now...
      Did I mention "..." ...
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        Hot engine?
        Mine...at 360k km had 160, 160, 150, 160, 150 psi.
        That 8.5 bar dosint look too good.
        • caterpillar
          • 2480
          have some oil in,, se if its the ringland or the walve.... komp will raise big numbers.. the piston or rings are gone,, will raise low mumbers.. the walves
          • stocious
            • Jul 2012
            • 838
            , wet test now !
            1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
              Up to 10 with oil
              • DJones
                • Jun 2005
                • 2020
                It will need pulling apart I'm afraid...
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  Good excuse to upgrade the engine. Sorry to hear this...
                  If the bores are ok....not too expensive to rebuild.
                  • stocious
                    • Jul 2012
                    • 838
                    I phone edit !!
                    At meat you know now which is sometimes the hardest bit! Sorry to hear rusty
                      I'll just have to put up with it for now and work out the best way forwards. Ideally, I'll just bolt in a lower mileage engine for now and get mine rebuilt at a later date
                        1. 10
                        2. 10
                        3. 10
                        4. 8.75
                        5. 10.5
                        Comments please...
                        I am sure it is annoying and you will want to eventually solve the issue (apparently a ring on no. 4) but it is within the factory limits:
                          This was cold as well, so I should do the same hot and test it.
                          Good to know it's within spec though.
                            Warm/hot should hopefully make things better.
                            Not all better, like warm cocoa and biscuits, but better.
                              It only puffs oil from cold, so that may well be the case for now. I'll have a look after a drive tomorrow or next weekend.
