Converting 7a Cam Cover to ABY
  • Colesy
    • Feb 2009
    • 2980
    Originally posted by UrS4boy
    The other one (with the pink flow lines in the diagram below) is for venting the oily vapours that build up under the cam cover (which could be released if you took the oil filler cap off with the engine hot and running). Must have been a concession to the TUV/Greenies in order to keep the overall potential engine emissions down:
    So has anyone actually blanked off this hose at all before? Would make things much easier than having a new pipe welded in.
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      As an answer....the 3b engine from 200 20v turbo....didint had that breather...
      no head breather at all...
      so.. i think is no problem to plug that.
      Hope this helps!
      • Colesy
        • Feb 2009
        • 2980
        I've had my cover machined now here are the results:
        Now the cover just needs a good clean!
        I can get this done again for other forum members, PM me for details. The specs I went for are a mix of the above solutions. The holes have been bored to 1.222" and a depth of .775" and the knotches cut out to an angle of 30 degrees to clear the oil cap. The rubber of the coils then needs to be trimmed to the same lenght as in AndyP's conversion detailed here
        I haven't fitted yet but it all looks good to me.
        • LHD_Kid
          • May 2006
          • 3695
          The photos aren't working, or is it just me?
          • Colesy
            • Feb 2009
            • 2980
            Now fixed.
            • prj
              • Mar 2010
              • 6308
              Just needs a clean and it should look great
              • driftin jo
                • Sep 2007
                • 2222
                Do you have the short or long coils ?
                With the longer coils you don't need to cut the rubber at all
                if you have the notches machined out as you have.
                The longer coils part numbers are:
                RED 06E 905 115E
                BLACK 07K 905 715F
                • Colesy
                  • Feb 2009
                  • 2980
                  RED 06E 905 115E
                  BLACK 07K 905 715F
                  I have the 115 coils. Should have said, it's the lower part of the rubber that needs to be trimmed not the top bit where the knotches go.
