No motive power
  • s2avant
    • 2426
    Just checked stock of the fuel pump and associated upgrade parts, no back orders so the two weeks quote is unusual. All they've done is superceded the coupe pump to the one used in avants. Maybe even audi realise the avant is the best choice and are secretly trying to convert coupes through superceded parts
    Code:
    Part Numbers are as follows:
    Pump     8A0 906 091 G     £62.50       6 available
    Pipe     895 201 355 B     £17.38       2 available
    Clip     N 024 122 2       £  .60     630 available
    Nut      N 011 182 1       £  .10      13 available
    Nut      N 011 181 2       £  .11       2 available
    Martyn might want to confirm part numbers with me, but from what I can work out there wouldn't be a problem getting the parts.
    Ben
    • Peter Dyer
      • 9
      One thing to check, before spending loads of money as happened to me with my 7A 90Q20V. Take the dizzy cap off and make sure: a. It can't be turned by hand, and b. It rotates when cranking.
      Could be that cr@ppy plastic drive gear. Just a thought.
      Pete
      • Mihnea
        • 1288
        Pete, good tip m8 but he's getting spark at the coil and at the dizzy, in case the dizzy gear is broken (Been There Broke That too BTW) you'll get absolutely no spark, the ECU gives no spark when the crank position sensor and the Hall sender's signals aren't in sync (and they aren't anymore when the dizzy gear is broked, Been There Saw That on my 3B too).
        HTH,
        Mihnea
        www.MRCTuning.com
        info@MRCTuning.com
        Workshop Directions
        • audiman
          • 4827
          I too have had the old dizzy gear break up. Gives no spark. And a dead car
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
          • dan_b
            • Sep 2003
            • 3670
            #20
            It is officially a knadgered fuel pump...
            Garage has gone direct to Bosch for a new pump, so should get the car back tonight. Hopefully it won't be too expensive.
            • dan_b
              • Sep 2003
              • 3670
              #21
              Aah, the blessed return of S2 power
