Part muber help for check valves
  • 220bhp
    • 2578
    • Home: United Kingdom
    Can anyone help with the part numbers for the one way check valve that is under the back seat for the diff lock on a 3b coupe. And also the one way valve in the engine compartment.Both are on the vacumme lines.
    Many Thanks
  • Thecrispynoodle
    • Jul 2012
    • 269
    Don't know about diff lock as don't have one but plenty into on the PCV valve under the inlet manifold here http://forums.quattroworld.com/s4s6/msgs/22506.phtml is that the one you mean?
      Many Thanks
      Diff Lock 101: http://forums.quattroworld.com/s4s6/msgs/170940.phtml
      • mcandmar
        • Apr 2004
        • 5118
        I believe the diff lock valve is 046905291A, and the engine compartment one 035103245A.
        The one in the engine compartment only has a plastic disk inside and can easily be opened up and cleaned if needed.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • 220bhp
          • 2578
          Many Thanks
