044 fuel pump
  • Thuppu
    • 4115
    From the Audi dealer + a banjo from ebay etc.
    • diesel des
      • 3896
      Oh great my friendly audi dealer. They arnt interested if your car is ovwr 5 years old here. Any part numbers
      • JP
        • 1858
        Can't remember if I dropped it into the original basket after trimming a ridge at the top or used the basked of the s4/rs4 dropped into the ur frame as been a while
        UrS6 Stroker + HTA3586 =
          Originally posted by 4WheelDrifter
          They're both the same pump. For inline you just add a fitting and hose to the base. I'm not sure if the one in the link is capable of 10bar TBH.
          I used to think the same but according to Bosch they are not they have different internals and are sent to a different production dept.
          • caterpillar
            • 2480
            #20
            the 044 and 040 have the same diameter, so it will fit right in... have done the job on a audi 200... have the 044 intank, instead of a 040... i used the the little sock from a volvo 240, in the bottom of the pump...the 040 does have the mesh in the bottom...
            • Costash
              • 878
              • Home: Romania Current: United Kingdom
              #21
              I ve order the basket from Audi ,was 25 quid from what I remember. Stock basket is way to narrow for 044 even the one I ve bough was a bit to tight and need a bit of trimming inside to push the pump all the way down to be properly installed.
              • diesel des
                • 3896
                #22
                Do you have the pn of the basket. Cheers
                  Originally posted by diesel des
                  Were would you get a mounting kit to fit a 044 into a urs4 tank?
                  One stop shopping here:
                  • A1QSHIP
                    • Aug 2004
                    • 975
                    I used a basket from a V8 fuel tank to install in the S6.
                    "Nulla tenaci invia est via"
                    • Avantus
                      • Sep 2007
                      • 941
                      • Country: Belgium
                      #25
                      I bought mine from Loba Motorsport, kit with basket.
                      Only this is that you still need to fit a non return valve.
                      http://www.ebay.de/itm/Original-Bosc...item5ae1375ad8
                      • Costash
                        • 878
                        #26
                        Here you go mate:
                        895 201 531 A Strainer
                        N 903 307 01 Adapter / Banjo
                        N 013 812 8 Sealing Washers x 2
                        N 011 069 1 Domed Nut
                        • Thuppu
                          • 4115
                          Originally posted by Costash
                          Here you go mate:
                          That banjo will not work on a UrS4/6. You need a banjo with a hose fitting, like this:
                          • Costash
                            • 878
                            #28
                            Didn t know is a urs4
                            • diesel des
                              • 3896
                              #29
                              Thanks guys
