Help timing issues
  • Maddogmark
    • 19
    Help timing issues
    I have an a4 1.9tdi ahu engine. Bought with a misfire due to a heater plug breaking and attacking valves and piston, so i fitted a new engine. last month after 6000 miles 2 hydraulic tappets obliterated them selves had the head rebuilt all new hydraulic tappets and valves i had 1 tappet seize in the head causing the piston to slap off the valve after 2 days of running even grumpier face. Now i am running again but smoking is there any audi heads in the co durham area who would help, have a look or even ensure my timing is perfect. Please.
    Thank you.
  • ManiacuV6
    • Dec 2009
    • 458
    • Country: Romania
    For a perfect timing you need to check and adjust it using an VAS or at least a VAG COM /VCDS. You should have a hot engine ( coolant at 90 deg ) for a good job.
    Audi S4 2.2T 5 spd 1992 for parts
    AUDI A4 1.9TDI daily use
    Audi 80 Quattro 2.0 16V (ACE) aka Competition
    • Monkeymagic
      • Mar 2012
      • 3419
      is it a pd. if so checking the timing is quick and easy. what colour s the smoke!
      • Maddogmark
        • 19
        Turns out it was an injector.
        Fixed now
        • ManiacuV6
          • Dec 2009
          • 458
          • Country: Romania
          Ahu is not a PD engine. AJM is a PD engine.
          Is good that you fixed your car.
