How do I get 300 bhp out of my aby s2 and how much will it cost
300 bhp
Tags: None
you can get 280-290hp with just a remap - £200 ish
a reliable 300 requires turbo & injectors & remap. If you are doing that you may as well add an exhaust manifold and intercooler and go for 400
Imola B6 S4 Avant -
300hp is not a good target because the stock turbo won't make that.
You can get ~280hp from just a chip with very little cost ~£200
if you are going with bigger injectors / turbo you may as well go for 400hp
as the cost will not really change for a 300-400 hp set up.Comment
Thanks for replys lads I'm in Rotherham is there anyone round here remap them £200 is cheaper than I thought thanks againComment
If you want something relatively straightforward then you can't go wrong with one of Mr Nugent's finest on a stock set up. If you want more you'll have to enter the dark side, hand over all your cash and submit!
2001 996 C4 - Being renovated
1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
