How much engine oil?
  • Rikki Kitto
    • Feb 2010
    • 6276
    How much engine oil does the S2 hold exactly? some oils are sold in 4lt some in 5lt which to go for?
  • mackenzie50
    • Mar 2010
    • 740
    4.5 litres if your sump isn't pissing it back out like mine has just started to do...only just got it back ont'road too!!
    • Rikki Kitto
      • Feb 2010
      • 6276
      Sad times, thanks for the help though and good luck with the car
      • robo
        • Aug 2004
        • 2086
        It will be about 4.8L if you drain oil from the cooler.
        sigpic_________
        Rob
        • mackenzie50
          • Mar 2010
          • 740
          Thanks!
          • shaun5
            • 1610
            Thats what i was gunna say, i take my oil cooler pipes off and blow it out
            • rj scotty
              • May 2006
              • 2195
              The theory being the cooler is the lowest point and holds oil you wont get out via sump?
              BUT I DON'T WANT A NEW CAR!
              1995 S2 Avant, Volcano Black
              • andy10v
                • 5996
                Get 5L
                Approx 4.5 for a sump drain only oil change.
                I cant remember if the cooler is lower than the sump, but it forms a U so oil does not drain out, it is forced round in normal use.
                Sold ABY-stock
