RS2 newbie seeks help on spark plug removal
  • Jimmypatch
    • Mar 2013
    • 57
    Hi guys, I've had my 1994 RS2, 134000 miles since Saturday, I want to change the sparks. Is there an easy way to get them out? By the looks of it I have to remove the throttle damper bracket !!!
    RS2 1994
    Mercedes G Wagon 1987 3.0D SWB
    VW T25 2.0 twin turbo Subaru legacy engine 300BHP
  • S2TORNADO
    • Jan 2008
    • 620
    yes, remove the damper bracket, then the cover.
    • Drummer87
      • Oct 2009
      • 1644
      • Home: United Kingdom Current: Scotland
      And the inlet pipe be careful on the throttle body torx screws as most will say, they are like putty very soft metal.
      • Jimmypatch
        • Mar 2013
        • 57
        Yeah they are soft one is already chewed up, I'm tempted to fire up the angle grinder
        RS2 1994
        • Drummer87
          • Oct 2009
          • 1644
          Either weld the likes of an alloy key to it. Then replace with new bolts. Tried an oversized torx and hammering it and slowly turning the bolt?? They are torxed that higher. Saves the angle grinder
          • tscheel
            • May 2009
            • 222
            • Country: Denmark
            Be careful not to over tighten the plugs - look the proper torque up.
            Cheers, Torben
            '94 B4 Avant S2
            • BrianSmith_S2
              • Jun 2005
              • 1342
              • Home: Northern Ireland Current: British Antarctic Territory
              Also be careful not to damage the rubber coilpack boots when lifting out the cover, as splitting them will cause arc problems.
                Here is a link to a Spark Plug Changing info post that I did for noobs with the AAN engine (in the C4 sedans and avants). It will be similar for you once you get the throttle body out of the equation.
                That spark plug DIY was actually linked out of an ignition coil info post that is just one of the hotlinks in the engine bay device map linked below. While the map is based on the AAN engine, it applies equally well to the ADU in your RS2 (and the ABYs in the S2s). I suggest that you might want to a) book mark it and b) have fun exploring it by clicking on the labels (hotlinks to info):
