Options for urq alloy radiator
  • diesel des
    • 3896
    So im fitting a 20vt to a urq. I intend in useing an alloy radiator and I see allisport sell some high capacity 63mm ones. Any one use them? Or any other options? I heard some manufacturers are to be avoided so hence the questions. Cheers des
  • diesel des
    • 3896
    Something like this http://www.ebay.co.uk/itm/330770074044
    • diesel des
      • 3896
      Or http://www.alloyracingfabrications.c...-radiator.html
      • URquattroGus
        • Aug 2007
        • 547
        Just to let you know; I still run the standard rad with no issues at all on the AAN.
        Thought about an alloy one, but seems unecessary at the moment. If what allisport say is true (30% better than standard rad), then their standard alloy radiator should be more than enough, as opposed to the extra thick one.
        I have an intercooler in front of the rad too, so a thicker one was a no no for me.
        Will Hollman in PPC mag had this rad fitted to his quattro, but then they do have some sort of advertising deal with them.
        Angus
        (1984 ur quattro)
        • Pembo
          • Aug 2004
          • 295
          I had an all metal radiator re-manufactured with 4 cores. No need to run the auxiliary radiator either. I used Dixon Radiators in Denton, Manchester. 0161 336 2705 Ask for Alan.
          http://www.yell.com/b/Dixon+Radiator...irections.html
          Pembo
          quattro - Original 4WD rallying
          Rally Car photos
          • jsws3
            • Apr 2012
            • 1174
            I have the 66mm one but its not fitted its very well made .
            • george21
              • Aug 2007
              • 226
              • Home: Lithuania Current: United Kingdom
              you can give a call to this guy, his name is Bob, he can do ANYTHING you want from aluminium and quality is no chineese metals used.
              • adam g
                • Feb 2007
                • 445
                Angus do you still have the aux rad? Im also planing to use the standard rad with aux removed on an ABY (hopefull 400 bhp) and wondering if it will be up to the job.
                I have ensured all rad ducting is in place though, something often overlooked which makes a difference.
                • URquattroGus
                  • Aug 2007
                  • 547
                  Aux rad chucked away long ago. (Yes I sold it)
                  Helps airflow into the engine bay, and remember the 10v was a non crossflow head with everything cramped up on one side.
                  Pete Berry sugested it based on experience and it's been fine.
                  Obviously, make sure your rad is not corroded or silted up.
                  They can be refurbed. I also have the original electric fan on the back. Cuts in less now than on the 10v
                  Angus
                  (1984 ur quattro)
                  • diesel des
                    • 3896
                    Some interesting stuff here. Im not sure my stock radiator is in great order. I will be dumping the aux rad. What about the fan. For track days is stock ok. Cheers
                    • jade
                      • Jan 2005
                      • 1811
                      • Home: New Zealand Current: Spain
                      I think you guys are fine, I run a RS2 with 550 plus in Spain big oil cooler no aux rad and I do not run more than 92 deg with the stock rad in summer
                      RS 2 580HP
                      • diesel des
                        • 3896
                        Thats interesting. Any links to good stock urq radiators then.
                        • jsws3
                          • Apr 2012
                          • 1174
                          I have a good ur rad if you need one .
