Today i made conversion to 1.8t coils.
Started the car and it was very lumpy.It sounds exactly some rally cars at idle..All cylinders fire,can see that if i stabilize it to 2500 rpm. Today no access to vag com so i started changing parts.Maf,tps,icv.Did a boost leak and found nothing up to 1 bar.Only few little bubbles at isv.Put back the stock coil pack.The same.
Car run perfect few days ago.Was left with + connection to battery removed and coil conversion was all it was done to it.
Afr gauge shows approx 15:1 and very lean changing 1 or 2 times a second according to engine lumpy behavior.
If i stabilize it at 2500 rpm afr fluctuates 14-15 and after 10 seconds starts to be lumpy again.
Something wrong with ecu because of the coils?
That lean afr could be spark cut or fuel cut.
). Fixed the wire and now the engine runs properly.
