RS2 motor mounts
  • Laaf
    • Oct 2010
    • 275
    I had a quick look at the 034 Track Density line mounts I've got, both has separated the cushion from the casing which I've noticed before. And today when I looked at them a bit closer I noticed the rubber was cracked on both around the mounting hole. But new ones are on their way home the really solid ones 034 are offering, hope they are going to put up better than the Track Density ones.
    • madpugger
      • Sep 2007
      • 1901
      Tom, I recently got a set of A/C ones from Pete at QC for my avant, it was 18 months ago or so, but they have only done a couple K miles. If you can get non A/C ones and want mine - in the interest of OEness on your car...
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • saltinot
        • May 2004
        • 1946
        I might take you up on that Mike.
        I received my two new right side mounts (8A0 199 382 D) from Audi and tried to install them on the left (radiator) side. The bolt holes don't come close to lining up. Anyone know what to do?
        • saltinot
          • May 2004
          • 1946
          Anyone have a couple of pictures of a left side mount off the car? One from the top would be nice.
          • madpugger
            • Sep 2007
            • 1901
            The left and right are different Tom.
            I may have pictures over weekend for you.
            Le Mans 2012
            Nurburgring 700
            1995 S2 Avant
            • irishs2
              • Apr 2009
              • 2455
              I am really sorry tom, it looks like I led you astray, I know I got two the same from QC and I didnt have trouble, but maybe they wernt audi oem ones, but now that you mention it I went out to have a look and I am really sorry but you are right in your findings.
              The holes on the turbo side are not wide enough .
              Eric
              95 S2 Avant under rebuild.
              • Kroegarn
                • 92
                You will have to be the judge of which one is the left side These once have been replaced with a set of too hard ones Too much noise, but on the other hand the engine twisted so much that the downpipe touched the inner arch, prior to the replacement.
                B.t.w you have one of the most impressive projects around..
                /Mike
                S2 RS Avant@355hp "For sale"
                A4 Avant TDIq@170hp
                Datsun 240Z@550hp
                BMW M3 race car@321hp
                Garage
