I have a theory that my poor idle is caused by a clogged PCV, so I'm taking it off and cleaning it this weekend. I could find some writeups on the ABY, but none on the 3b.
The reason for my theory is that the car had the same idle with my 7A engine (low hot idle, 550 rpm), and the only parts ive used over is parts of the PCV system.
It has a new coolant temp sensor in the head and a good working ISV. The only other reason I can think of is a leaking DV.
